#  OBD Gauge
#  Copyright (C) 2004 Dana Peters
#  This program is free software; you can redistribute it and/or
#  modify it under the terms of the GNU General Public License
#  as published by the Free Software Foundation; either version 2
#  the License, or (at your option) any later version.
#  This program is distributed in the hope that it will be useful,
#  but WITHOUT ANY WARRANTY; without even the implied warranty of
#  MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.  See the
#  GNU General Public License for more details.
#  You should have received a copy of the GNU General Public License
#  along with this program; if not, write to the Free Software
#  Foundation, Inc., 59 Temple Place - Suite 330, Boston, MA  02111-1307, USA.
#  Palm OS Generic Makefile for Eclipse v1.0.0
#  PalmOS4/68K
# Fill in this file to specify your project and the source that you want
# to build, and the settings involved in the build. The makefile-engine.mk
# will then do the hard work of the makefile and dependency handling.
# After starting a new project, please remember the following steps...
#	1. Add all sources and resources in SOURCES and RESOURCES
#	2. Review the other settings as needed.
SHELL = /bin/sh
# Set up the artifact name, which is the root name of your project's output
# without the extension.
# The PRC and/or static library name, the database name, and other file names
# are based on the artifact name
ARTIFACT_NAME = OBD Gauge
EMPTY =
SPACE =$(EMPTY) $(EMPTY)
ESCAPED_ARTIFACT_NAME = $(subst $(SPACE),\ ,$(ARTIFACT_NAME))
PRC_NAME = $(ESCAPED_ARTIFACT_NAME).prc
LIB_NAME = $(ESCAPED_ARTIFACT_NAME).a
# Sources and Resources
# List all the sources (.c/.cpp) and resources (.xrd) in your project
# Use project relative path names with forward slashes (src/code.cpp).
# Please do not use spaces in directory names.
# A note about XRD resource files:  If you have existing .rsrc or .rcp files,
# refer to the documentation for the GenerateXRD tool to convert them into
# XRD files for use with all Palm OS SDKs.
# TODO: Update all sources and resources
SOURCES = src/OBDAccel.c src/OBDCodes.c src/OBDCommon.c src/OBDGauge.c src/OBDPrefs.c src/OBDRead.c src/OBDSensor.c src/OBDSerial.c src/OBDWait.c
RESOURCES = rsc/OBDGauge.xrd
SLIB_DEF_FILE =
# Specify if this application has multiple sections
# If TRUE, then Sections.def file must be part of the project
MULTIPLE_CODE_SECTIONS = FALSE
# Review Database information
# Register Creator ID at: http://spp.palmos.com/iws/creator/searchByEmail.jsp
CREATOR_ID = obdg
DB_TYPE = appl
# to enable reset on install, use -r
DATABASE_RESET =
# to enable backup, use -b
DATABASE_BACKUP = -b
# to make the app hidden, use -h
DATABASE_HIDDEN =
# to prevent copy, use -p
DATABASE_PROTECT =
# to bundle the application with its databases on beaming, use -dbFlagBundle
DATABASE_BUNDLE =
DATABASE_VERSION = 1
LOCALE =
DATABASE_NAME = $(ESCAPED_ARTIFACT_NAME)
# Build Settings
# Review the following for your needs.
# The default settings build with debug information and no optimization.
# Set Debug or Release configuration here
DEBUG_OR_RELEASE=Release
# Set the target platform for the build; either Device or Simulator
# Use Device as a target for emulator builds.  For 68K projects, this
# option doesn't really affect the build; 68K code is built for both
# device and simulator targets
TARGET_PLATFORM=Device
# Specify the level of optimization that you want
# NONE, SOME, FULL
OPTIMIZE_LEVEL =
# Specify warning level
# NONE = supress all warnings
# ALL = enable all warnings
# <undefined> = default warnings
WARNING_LEVEL =
# Specify if warnings should be treated as errors
# TRUE, FALSE
WARNING_AS_ERROR =
# Specify verbose output
# TRUE, FALSE
VERBOSE =
# Additional paths to look for #include "header"
# (Source file directories are automatically included)
# Please note that both local and system include paths should
# either use "cygwin" syntax or if in Windows syntax the should
# be quoted; i.e. ../MyLibrary/headers or "C:\Source\MyLibrary\headers".
# Additionally, you must explicly specify the "-I" prior to each
# path included in this variable.  Spaces are used to separate
# each path from each other.
LOCAL_INCLUDE_PATHS =
# Additional paths to look for #include <header>
# (Palm OS SDK directories are automatically included)
SYSTEM_INCLUDE_PATHS =
PRE_INCLUDE_PATHS =
# Specify any needed preprocessor symbols.
# If you set DEFINES to "ASSERTLEVEL=1", the compiler will see "-DASSERTLEVEL=1"
# (separate individual entries with spaces)
DEFINES =
UNDEFINES =
# Specify additional compiler flags for all files
ADDITIONAL_COMPILER_FLAGS =
# List additional libraries to link with
# (Full or project relative path)
ADDITIONAL_LINK_LIBRARIES =
ADDITIONAL_LINK_LIBPATH =
# Specify additional linker flags
ADDITIONAL_LINKER_FLAGS =
# Tools Directory
# Normally you wouldn't want to override this since the necessary tools
# are in the PATH.  But if you experimenting with other tools, then
# reset the directory here
# If overridden, end with a trailing '/'
TOOLS_DIR =
# Resource Settings
# Specify the target text encoding
# LATIN, JAPANESE, SIMPLIFIED_CHINESE
PRC_TEXT_ENCODING = LATIN
# Specify resource locale checking
# TRUE, FALSE
PRC_NO_LOCALE_CHECK =
# Specify strict resource locale checking
# TRUE, FALSE
PRC_STRICT_LOCALE =
# Specify if text encoding should be checked
# TRUE, FALSE
PRC_STRICT_ENCODING = TRUE
# Specify overlay filter value
# BASE, OVERLAY, FULL, <default>
PRC_OVERLAY_FILTER =
# Specify no warning on resource size
# TRUE, FALSE
PRC_NO_WARN_SIZE =
# Specify quiet output or not (opposite of verbose)
# Use PRC_QUIET for PalmRC invocations
# Use PRCMERGE_QUIET for PRCMerge invocations
# TRUE, FALSE
PRC_QUIET = TRUE
PRCMERGE_QUIET = TRUE
# Additional flags for Resource compiler and linker
ADDITIONAL_PRC_FLAGS =
ADDITIONAL_PRCMERGE_FLAGS =
# Output Settings
# Modify if you want object and output files to be in different locations
# (However, please note that all four object directories must be different
# for the makefile engine to properly operate.)
# Initially, device and simulator builds go to the same output directories
# because the 68K compilations steps and outputs are the same for both targets
DEBUG_DEVICE_OUTPUT_DIR := Debug
RELEASE_DEVICE_OUTPUT_DIR := Release
DEBUG_SIMULATOR_OUTPUT_DIR := Debug
RELEASE_SIMULATOR_OUTPUT_DIR := Release
# Makefiles
## conditionally include an auto-generated.mk for dynamic definitions
-include auto-generated.mk
## include the makefile engine
include makefile-engine.mk
## conditionally include your own custom.mk for your specific overrides or definitions
## this is useful if you don't want to use the auto-generated.mk values
## for some reason
-include custom.mk
